this is a long and confusing problem, but i'm hoping that someone else has seen this before...
i have windows XP and a hauppauge win-tv GO capture board. i installed all the latest drivers, and it worked fine capturing with virtualdub.
however, it would only work until i shut down my system. then, each time i want to use it, i have to uninstall the drivers, reboot, reinstall the drivers, reboot again, and then it still only works until i reboot or shut down.
even when it IS working, i get invalid format errors when i try to capture using some codecs, and can't even select the huffyuv codec in virtualdub OR premiere.
anybody know how to fix this?
Did you upload the latest drivers from Hauppage, yet?
Hello. -
Virtualdub will only work with VFW drivers, not supported in XP. So, you will have to install a WDM to VFW wrapper to use WinTV Go under Windows XP and Virtualdub. iuVCR will work directly with the WDM drivers, and give you full resolution on captures. (I believe the WDM to VFW wrapper is limited to x240 resolutions)
Win Defender update (KB915597) causes my windows XP to restart after 2 mins
By Denvers Dawgs in forum ComputerReplies: 9Last Post: 5th Feb 2009, 17:39 -
Windows Update claims my legal Win XP is illegal
By General Mortars in forum ComputerReplies: 17Last Post: 26th Aug 2008, 21:54 -
big conversion problems
By insyder in forum Video ConversionReplies: 0Last Post: 7th Jan 2008, 11:02 -
BIG problems with subtitles!!!!
By patoja76 in forum Authoring (DVD)Replies: 1Last Post: 11th Aug 2007, 12:00
