Hi folks,
I have been using Windows Movie Maker to capture, then encode to DV-AVI but the audio is out of sync with some of the clips I created...how annoying. Why does this happen?
What would you recommend I use to capture and in what format? I have Adobe Premiere 6.0...should I use that?
Also,should I then encode to MEG1 using TMPGEmc to give me better quality? It appears to do a bang up job. I then create VCD's for play on my DVD Player.
Let me know, I need some sound advice here.
Thanks,
Magma
You may capture using Premiere IEEE 1394 Firewire (or even the free DVIO.exe) to capture and edit using Premiere. Then frameserve to TMPGEnc to produce VCD/SVCD/DVD compliant MPEG files. Check if this also causes audio sync problem.
Hi folks,
I have been using Windows Movie Maker to capture, then encode to DV-AVI but the audio is out of sync with some of the clips I created...how annoying. Why does this happen? My OS is XP home edition. I have a cable IEEE1394 to conect to my laptop SATELLITE
Thank you
I hope somebory help me please...
Web encoding & playback format recommendations ?
By PowerFalcon in forum Video Streaming DownloadingReplies: 10Last Post: 17th Jul 2011, 14:26 -
encoding after capturing
By krohm in forum Capturing and VCRReplies: 2Last Post: 4th Jan 2011, 12:27 -
Capturing from VHS to divX: Recommendations (Flicker & freezing proble
By roylayer in forum Capturing and VCRReplies: 2Last Post: 26th Sep 2008, 18:00 -
H.264 to MPEG-4 encoding recommendations?
By sjk in forum MacReplies: 0Last Post: 10th Jan 2008, 16:23 -
Software Recommendations for Capturing MPEG2
By scienceguy_4 in forum Capturing and VCRReplies: 7Last Post: 4th Oct 2007, 20:59
