i have been running my video from media 100i into cleaner and then droping into toast 4. i have toast selected in my setting but it will still not play back on any DVD player. it wont read the disks. i am using the Blus Verbatim CD-R 80's. What in the hell am i going wrong. Cleaner's web site lists that i should be able to burn a VCD with toast 4 as long as it was converted before droping it in, but i only have data folders or audio as burning options.
You need Toast 4 Deluxe, or better yet, Toast 5 Titanium. The OEM version of Toast won't burn VCDs.
Toast 7
By JordanBlake in forum Newbie / General discussionsReplies: 0Last Post: 7th Jun 2010, 16:07 -
Alternatives to Toast
By danielmak in forum MacReplies: 6Last Post: 17th May 2010, 00:37 -
Toast 9
By lawnman in forum MacReplies: 1Last Post: 11th Mar 2008, 23:45 -
Toast 8.0.3
By lawnman in forum MacReplies: 1Last Post: 17th Nov 2007, 07:00 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54
