Can someone tell me the differences between these encoders, which one they like better etc.
And tell me why one CCE costs 2 grand and another a couple of hundred, then there's TMPEGenc which is very inexpensive.
Thanks,
scottymac
Results 1 to 11 of 11
I can't say anything about CCE (since I don't have the $2,500 to buy it and try it) but I have used Tmpeg many, many times and it is great. Even though it is "freeware", I purchased it (for $48) because it is one of the few programs that I have seen that is well worth every penny.
Some will claim that video streams compressed using CCE are better than Tmpeg and vice-a-versa. I think they are both quality but Tmpeg is the best for the price. -
I have used both and don't see much difference between them at high bitrate MPEG2. However, CCE is less blocky at lower bitrates.
I use it to create XSVCDs at 720x576 (PAL) with a bitrate of 4000kbps from miniDV with great results. TMPGEnc tends to show blocks at the same settings.
The biggest difference between them is speed. CCE is about 3-4 times faster.
Using the above settings my system encoded 25 minutes of AVI in about 4 hours. CCE took 1 hour 15 minutes. -
@Scottymac:
So you topic tread doesnt get way off point. Please do a search through old posts. The ideals of both sides have been hashed out time & time again. -
CCE is faster. CCE is able to do more then 2 pass encoding so quality is not an issue. I think that is the biggest difference.
for the most part, if your only doing vcd then tmpg should be fine. but if you want to make high quality mpeg-2 files then no question CCE is the way to go. -
You can make high quality SVCD very easily using TMPGEnc. Do not believe that you have to pay out several thousand dollars! 8)
Take a look at http://www.svcd.cc/index.htm or at the guides on this site using TMPGEnc. -
TMPGEnc is definitely a good encoder.
Most experienced encoders consider CCE to offer better quality if you are willing to learn how to optimise each encode.
I agree with Kdiddy in search the forum for previous posts. There is an absolutely plethora of opinions on this issue.
Regards.Michael Tam
w: Morsels of Evidence -
CCE is more compatible with most systems, runs faster and more stable. That's what you pay extra for.
CCE is more compatiable? Don't get that part.
TMPGEnc = Slow
CCE = Fast
TMPGEnc = Free
CCE = Far from free
TMPGEnc = Great VCD encodes
CCE = Poor VCD encodes
TMPGEnc = Great SVCD encodes
CCE = Great SVCD encodes
people will argue CCE provides better MPG2 encoding, while maybe true, doesn't matter both are great, TMPGEnc is free to boot. -
If you know where to look, CCE is just as free. Trust very few on these forums if any have actually shelled out a couple grand for CCE.Originally Posted by Faceman101
yea, but better keep it down a bit as there is a bullet on top saying
Do NOT ask for warez, give warez or link to warez.
when I type this...
White Screen in TMPEGEnc 4.0
By barrylay in forum Video Streaming DownloadingReplies: 0Last Post: 1st May 2011, 16:09 -
TMPEGenc h.264 conversion error
By iGnight in forum Software PlayingReplies: 2Last Post: 16th Jan 2011, 11:14 -
Remove subtitles from MKV when converting with TMPEGEnc
By ikarishinji41 in forum Video ConversionReplies: 3Last Post: 10th Dec 2009, 11:21 -
TMPEGEnc DVD Author Ordinal Error
By justin81 in forum Authoring (DVD)Replies: 2Last Post: 17th Aug 2009, 21:33 -
TMPEGENC keeps closing itself because of an error
By Akhet in forum Newbie / General discussionsReplies: 1Last Post: 14th Oct 2007, 01:38
