i bought 5 dvd silvers at xmas for my kid , jungle book , bugs life , grinch , shrek and tigger movie . They all played fine for a while then a couple of them started showing a green band across the screen , it went away if you pressed stop and play (resuming from same spot) . It became more frequent then recently i removed the top of my dvd player YELO 8000 (KIIRO MADE) and cleaned the lens , great the band had stopped appearing after cleaning the lens , now a few weeks on this band is back same as usual , cant be a dirty lens already .
Has anyone else experienced this and can you advice me on what to do . It does not happen with genuine dvd's and never with any vcds . It obviously is not part of the dvd as it goes away if you presss stop then play .
Results 1 to 1 of 1
Pinnacle DVD menu green screen SOLVED!
By Surg1951 in forum Authoring (DVD)Replies: 2Last Post: 27th Feb 2011, 16:12 -
Green Band Problem
By fusion99 in forum Blu-ray RippingReplies: 4Last Post: 6th Aug 2009, 12:58 -
green band after using restream
By thecrock in forum Newbie / General discussionsReplies: 0Last Post: 15th Dec 2008, 15:37 -
Premiere Pro 2.0: strange green vertical band in Program Monitor
By spicediver10191 in forum EditingReplies: 3Last Post: 20th Oct 2007, 01:46 -
Vertical band moving across screen - DVD/HDD recorder
By wizbru in forum Newbie / General discussionsReplies: 3Last Post: 16th May 2007, 03:20
