I want to ask a question - Do I get best SVCD results from my footage, or there is something else to be improved? I mean quality, not file size. I looked at samples presented at vcdhelp.com and decided that my mpegs are too blurry. I dislike even mpeg made with dvd template.
Here I post links on some screen shots that I made.
I converted them to JPEG to save your download time, but they look very very much like orignal BMP shots. All shots are made in fullscreen mode. AVIs are shooted from VDub, MPEGs - from WinDVD.
Original avi. It was captured 720x540 3Mb/s by Pinnacle Studio 7 through DC10+ card. The source was a video 8 cam.
Mpeg created from original avi by TMPEGEnc using wizard's DVD settings.
Mpeg created from original avi by TMPEGEnc using wizard's SVCD settings.
Original avi after deinterlacing in Virtual dub.
SVCD sample that I downloaded from vcdhelp.
Well - I don't know about "bad" - the stills look ok - I hope the washed out colour and brightness is a problem with your screencap applic
The SVCD sample is OK
It would be nice to see a motion clip though
If your creating for display on TV - don't bother de-interlacing
You won't notice any difference on TV - well hardly anything anyway
Other than that, being really picky I would
increase the colour saturation slightly in the MPG encoding stage
you look like you have reached the quality limit for a Hi8 camera - what is your Picvideo codec settings. Don't bother with anything over 17
depending on your target audience - try going for standard VCD format - unless they are involved in sports or extreme motion activity
I suggest VCD as reducing the frame size can actually make some footage look better this might just work ok for you
Try a couple of encodes and see what you think for yourself.
Joining more than 2 mpegs...
By artphotodude in forum ffmpegX general discussionReplies: 2Last Post: 30th Jul 2011, 10:33 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 05:48 -
Windows Movie Maker: AVI's sound bad, MPEGs won't play
By Canopus Smoker in forum Newbie / General discussionsReplies: 3Last Post: 26th Nov 2008, 11:54 -
Bad motherboard or bad CPU?
By videohalp in forum ComputerReplies: 11Last Post: 9th Jul 2008, 11:07 -
Bad encoding? Bad installation
By lo-q in forum ffmpegX general discussionReplies: 2Last Post: 22nd Sep 2007, 20:45
