  1. Ok, I had to convert the audio from a .avi to the 44,000Hz thing. Then when I tried to dub the new wav audio to a new .avi the program (VirtualDub) said the file would be too big. The file was expected to be a Gb and it suggested I compress the video. What should I do??? I am really confused...
    Jan 2001
    Brisbane, Australia
    By default VirtualDub defaults to no compression when saving an AVI
    It was just giving you reminder that the resulting AVI would be very large
    Set a codec to compress the video to a managable size
    If you are cleaning up a AVI file - try and match the input codec
    You can find it under file information
