  1. I'm trying to encode a bunch of mpegs in batch mode. However, everything I add a bunch of projects and do a run it only encodes the first one and exits. Does anyone know why this is occurring? I'm tried many versions of TMPGenc (2.53, 2.54, 2.55, 2.56) and have the same problem. Also, the shutdown function does not work. I'm running Windows XP.
    Thanks!
  2. I've got the same problem.
    And if I restart TMPGEnc the batchlist is gone.
    cleveland
    guys, select the entire list (it will highlight as blue), click on the 1st in the batch, then hold down the shift key, then click the last in the batch. Then click run. Good luck.
  4. That easy. Thank you very much for your help.
    cleveland
    no problem
  6. guys, select the entire list (it will highlight as blue), click on the 1st in the batch, then hold down the shift key, then click the last in the batch. Then click run. Good luck.
    That is exactly what I did. It didn't work. After the first item on the list is encoded it exists TMPGenc. Any other suggestions? Thanks!
  7. I had the same problem, running TMPGEnc under Windows XP. Version 2.59.47.155-Plus-EN, actually. So I tried testing keating5's advice, and it worked normally. I guess this is just one extra step to keep track of. :hrug::
