Hi,
Why would I get a message that reads "can not open or unsupported" when trying to convert an avi file to MPEG? Any way to resolve this?
what created the avi file if it was DVD to Avi try to make it again sometimes it has probs.
No, it's an avi I downloaded off the internet from Napster. It opens in Windows Media Player fine. I just dont know why it's not opening here.
there are many other programs you can try such as flask or avi to mpg ect do some searching. The only other thing I can say is to install the codecs again to see if they are conflicting some way. good luck
I'm getting this same error with 12i when trying to open a MPEG2 file. I can open the same MPEG2 file with 12a with no problem.
RF -
Found a workaround for this problem
http://www.vcdhelp.com/phpBB/viewtopic.php?topic=53750&forum=3
Problem loading Blu Ray files into TMPGEnc Authoring Works 4
By DSguardian in forum Blu-ray RippingReplies: 0Last Post: 14th Apr 2010, 20:52 -
Ripbot 1.14.6 is generating errors when loading a m2ts file
By playitagain_sam in forum Blu-ray RippingReplies: 0Last Post: 29th Dec 2009, 10:59 -
JVC DR-MH50S Loading Problem
By munish1000 in forum DVD & Blu-ray PlayersReplies: 9Last Post: 5th Feb 2009, 08:36 -
Major problem loading audio from AVI file into Auto Gordian Knot v 2.45
By robo5050 in forum Newbie / General discussionsReplies: 1Last Post: 7th Nov 2008, 07:12 -
MeGUI Problem loading File
By cjh1452000 in forum Video ConversionReplies: 6Last Post: 11th Jun 2008, 23:27
