I have a PIII 500 Mhz comp with 128MB RAm...and like 4 GB free
for an average 1 hour 30 mins movie...converting a DIVx to VCD..using TMPG...how long would this take....
thanks
Results 1 to 9 of 9
On my 466, 160mbs ram it takes about 9 hours for 90minutes about 12 for 120minute movies. Motion search precision is at Normal and dont use any filters.
im aslo curious to know how long it takes for the people with the top notch CPUs....wondering if its worth me putting some money out for an upgrade...
post with your times...and only post if you have a fast cpu thanks -
I don't know how fast you are looking for but I have a Athlon XP 1700+, 768 mb of DDR ram, and 7200 rpm hds and I encode straight vcd faster than realtime and SxVCD with motion search prec. at very slow at about 2 times realtime. Time to upgrade, dude. Build one yourself and save major bucks!
I'd rather have a bottle in front of me than a frontal lobotomy. -
Yes, definately upgrade your CPU. I used to have an AMD K6-500 and have now upgraded to a 1600XP and this gave me a 7 times increase in encoding speed. Definately worth it if you plan on making lots of VCD/SVCD/CVD's.
So the new XP 2200+ is out then? I just ordered one today... but seriously get an Athlon XP processor with a nice systemboard, the best you can afford. Stick with fast ram and your all set.
As much as you can live with; the faster your CPU, the faster your encodes will happen. Perhaps if you specify a budget amount (the crystal balls aren't working right this week).Originally Posted by CantholdmdAs Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
I suppose it depends on whether your existing motherboard will support a new processor. If so, then just buy the chip & fan for £100 or so an away you go. If not, then get a new motherboard for £75. Don't worry about RAM as 256meg of PC133 (fifty quid) will be fine, so just buy whatever your motherboard will support.
Decrease Conversion Time
By CranialBlaze in forum Video ConversionReplies: 0Last Post: 10th Nov 2010, 04:23 -
Blu Ray Movie Average Ripping Time
By wazza88 in forum Blu-ray RippingReplies: 13Last Post: 31st Oct 2010, 17:15 -
Framerate conversion (again sorry) 60p to 25p this time
By Panash in forum Video ConversionReplies: 5Last Post: 2nd Jan 2010, 17:32 -
Removing a running time from vhs conversion
By eiffelgirl in forum EditingReplies: 10Last Post: 4th Dec 2008, 00:41 -
What is the average time of ripping a dvd file to an AVI, or WMV
By ManhoefDream in forum Newbie / General discussionsReplies: 2Last Post: 4th Aug 2008, 14:49
