I am creating a vcd for a friends dvd player. The size of my file is a little too big to fit on one cd. i know theres methods such as overburn ect but what i want to know it can you reduce the bitrate of the mpeg and still be able to play the file on the dvd player. ? I only whish to chop it slightly less that the 1150 kbs. Ive heard of xvcd where u can adjust the bitrate up but compensate by reducing the sound rate to get the same standard overall. Can u do the opposite ?
Cheers
Phil (not overly quality mad but dont swapping cds)
Try to just reduce the bitrate or just reduce the audio to 128. If you higher one and lower the other then you wont be doing much. Check in the DVD Compatibility list to see if your dvd player can play XVCDs.
Swim with me
And we'll escape
All the trouble
Of the present age
Finally free
Bluray player calling blueray disk "data disk" and saying no video files
By jbitakis in forum Authoring (Blu-ray)Replies: 10Last Post: 27th Nov 2011, 22:06 -
Converting 2-Disk Sets to 1 Disk
By 1337assassin in forum Newbie / General discussionsReplies: 18Last Post: 23rd Oct 2010, 10:53 -
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 16:35 -
GPX D1816SIL dvd player and I can not use it to play VCD disk.What should I
By nyankum in forum DVD & Blu-ray RecordersReplies: 2Last Post: 13th Jul 2008, 13:15 -
Burning iso image from Hard disk to hard disk?
By When in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2008, 23:27
[/url]
