Hey everyone
I'm still pretty new to this, so i got a ton of questions, and here's my latest: How can i get the best quality rip?
What processes should i use to get the best picture and overall quality, which formats should i encode to? and which programs produce the best results? ( i hear that some mpeg encoding softwares are better than others)
If you know how to get the best results, please let me know! Thanks!
Mojo
Well first of all I want to say is that I'm also an newb at this. But I already tested several times. First thing you have to do is pick a format. Do you
1)want to play it only on your PC or
2)do you want to watch it on your standalone DVD player.
If you chose for 1 I think divx is the best format and if you want 2 I would recommend the DVD to CVD guide from baker, it gave me very good results. -
I definately want it to play on my standalone,
So is using DVD2SVCD the best program to use?
Mojo -
In my opinion, yes DVD2SCVD is the best(easiest) to use. Check the guides here and on doom9.org . They are well writen and easy to understand
Best quality DVD output software for maintaining photo quality
By P_Erickson in forum Newbie / General discussionsReplies: 20Last Post: 21st Apr 2012, 22:30 -
Bad quality WMV - will a conversion increase quality?
By nickbrace in forum Video ConversionReplies: 4Last Post: 20th Oct 2011, 04:48 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 19:23 -
3 AVIs to DVD low quality or medium quality to drive then DVDshrink?
By johnharlin in forum Video ConversionReplies: 5Last Post: 4th Apr 2009, 02:18 -
&fmt=18 does not give the same quality as playing by "high quality
By arminio in forum Video Streaming DownloadingReplies: 2Last Post: 9th Feb 2009, 18:33
