Whenever I try to play something I encoded using virtualdub and divx 5.0.2 pro, it plays just fine, but when I try to skip to anywhere in the file beyond half way through the file the program hangs. This happens when I use windows media player, virtualdub or ATI's media player. Anyone know why this is? The files are only about 20 min log.
This only happens on files which I recorded at 60 fps, other ones which I recorded at 30 fps seem to work just fine. Does anyone know why this is?
Microsoft states that WMP may not handle 60fps or higher correctly. As your other apps are also borrowing the same directshow codecs, that
limitation applies to them as well.
Long time burning and skipping problems
By championjosh in forum DVD & Blu-ray WritersReplies: 8Last Post: 16th Feb 2008, 02:11 -
Playback problems when manually skipping
By vanquish42 in forum Software PlayingReplies: 3Last Post: 6th Feb 2008, 06:36 -
VOB files skipping
By Mindg in forum Newbie / General discussionsReplies: 0Last Post: 23rd Dec 2007, 23:27 -
avi files burned to dvd skipping...any idea why
By cduval04 in forum Newbie / General discussionsReplies: 12Last Post: 8th Jul 2007, 03:10 -
Perfect VOB files of movie skipping when burned
By oinkyboinky in forum Authoring (DVD)Replies: 14Last Post: 29th May 2007, 09:51
