I have a mpg movie that is 16:9 and when I play it in Windows Media Player its still 4:3... ugly as hell. Now I want to play it in PowerDVD so i can change to 16:9 but i need to convert it to dat if its posssible.
So what program to use? Does vcdgear work?
Thx!
Why do you need it to .dat? PowerDVD can view the MPG. If you really want to convert it, right click it then click 'Rename' and rename it to 'filename.dat' Easy?
You only need .dat file when you burn on CD-R/W. Ahead Nero Burning ROM and many other software will do the job. Not sure about VCDGear, though.
DAT/MPG to VOB/MKV?
By coxanhvn in forum Newbie / General discussionsReplies: 2Last Post: 30th Jan 2011, 06:21 -
DAT to DAT cutter?
By coxanhvn in forum Newbie / General discussionsReplies: 2Last Post: 15th May 2010, 12:13 -
What is the DAT file?
By coody in forum Video ConversionReplies: 3Last Post: 22nd Mar 2010, 21:29 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48
