This is possibly a stupid question but I'll ask it anyway.
Can a video file such as MPEG/MPEG2 be converted and burned in DVD format onto a CD so it can be played in a DVD player which does not support VCD or SVCD.![]()
Results 1 to 10 of 10
I've been wondering that myself for quite a while now. Maybe it is possible, but who knows. I've thought about searching these forums before but have convinced myself that the only answer I'll find is no, and besides, too lazy, I mean, what would I search for: 'DVD' 'burn' 'cd' ? Jeez, theres no telling how many topics would show up, anyhow, I'm sure there will be a resounding no, but I'm going to try anyways and see where the snag is.
like Mini-DVD?
Very few players support itWell, I am the slime from your video.
Oozin' along on your livin'room floor. -
Hi,
My "research" suggests that it is possible depending on the player (as always for non-standard stuff)... but you'll only get 10-20 minutes each depending on bitrate. DVD at 4700 MB divided by a 700MB CD = 7 CDs per DVD which holds maybe 105 minutes of "Hollywood quality" movie (based on the "Matrix") which means maybe 15 minutes per CD. Which means changing disks six or more times to watch a movie... what a hassle.
Not only that, but I like to pick reasonable places to break a movie into disks (e.g. at a scene change) and this gets really hard, or wasteful, the more disks I need.
Allan -
OK I realise that DVD file split to cd would need 7+ discs but what I'm suggesting is a 750mb mpeg written to a cd but in a format that would make the player think that it was a dvd.
Perhaps it is the type of disc that the player recognises (layering, sectors or whatever) so it could not "see" a cd as a dvd? -
Hi,
You'll have to experiment.My "research" suggests that it is possible depending on the player (as always for non-standard stuff).
Allan -
Yes, it is possible. I captured about 20 minutes of a movie using Ulead DVDMovie Factory. I then authored it using the same program as a dvd, and burned it as a dvd, using the cd burner and a cdrw. It was recognized as a dvd on my sampo dve620 and my sony carousel dvd player. However, the funny part of all this, is that when I tried to do the opposite, burn a vcd onto a dvd, it told me that the medium was incoreect upon placing a dvd r in the dvd burner.
no search the forums for miniDVD and even my screen name, and you will get this quesiton asked & answered tens of times.
I'm sure this is an old topic by now, but I think what the question was actually was if the VCD or SVCD could be changed to be read by a dvd player by just changing the Header of the burned MPEG. It sounds reasonable, but I dont know much, I suppose it would still have to be authored and what not. But it would be just like changing the header of a SVCD to VCD for increased compability- if you want to call it that- personally I don't know of any software capable of doing that, later
Rip DVD-R's, edit out commercials, burn new DVD Dual Layer...software?
By ruehl84 in forum Authoring (DVD)Replies: 5Last Post: 23rd Feb 2012, 04:06 -
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 13:42 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 05:26 -
Advice required when trying to burn with img burn
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 1st Aug 2009, 17:29 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 21:46
