  1. I have created a MPEG1 file by using TMPEGEnc and
    created a VCD with VCDEasy.
    Everything works fine in the PC and VCD palys 100% perfect in WinDVD
    But when I am playing in the DVD player. it starts without any
    problem. But during playback sometimes a delay occures. But audio
    is playing without any problem.
    NB: I have already disabled the PBC off, while VCD creation.
    Please advice me what I am doing wrong.
    Thanks in advance
  2. Did you encode using the template on TMPGEnc?
    Regards.
    Michael Tam
    w: Morsels of Evidence
  3. First I used the template provided by TMPGEnc. I was getting
    the same problem. Quality of the movie was also not as per my
    expectation.
    At present I am doing KVCD template. I was getting excellent
    output in MPEG1 and MPEG2. Created VCD has got better quality but
    metnioed problem was persistent.
    I was going through the forum and found some clues about the writing
    speed. Is there any significance for writing speed ?
    Thanks for your enquiry.
    Dec 2000
    Övertorneå, Sweden
    What dvd-player do you have?
    Does other vcd's play well on your dvd-player?
    Have you tryed diffrent cdrs?
    Helmut
    # SNiGLA @ EFnet
    # vcdhelp @ EFnet
    # vcdhelp @ DALNet
  5. Dear Mr. Humlet,
    - I am using LG-3351P.
    - There is no problems with the DVDs and VCDs
    - Nearly I tried three different brand CDRs -Nearly 12 CDs waisted
    With regards
    Shaju
