has any one tried to to cvd yet
2 probs
ist prob no resize window on frame serve
and cdimage does not work
using win xp pro
could this be the problem
First problem: You have to use the newest DVD2SVCD, otherwise that window will not be there..Originally Posted by doug57
[Use edit avs after dvd2avi is finished, change size there]
cdimage I dunno why, give us some more info about the error.- Twin - -
You also have to chane the DVD2SVCD level to Advanced in the Misc Tab for the resize buttong to show in frameserver.
I'm having some trouble with BBmpeg freezing about halfway through. -
I've exactly the same problem on a machine I installed DVD2SVCD Build3: VCDIMAGE doesn not work.. seems that is is not run, no matter if VCDImager or VCDXbuild is choosen, whats up?
I uninstalled it...deleted the folder and installed the latest version of DVD2SVCD and everything is working again for me.
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 18:01 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 17:28 -
DVD2SVCD Vista compatibility
By Kibble in forum DVD RippingReplies: 5Last Post: 19th Mar 2008, 10:51 -
DVD2SVCD with CCESP 2.70 - CBR 6kbps? No way around?
By Colmino in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2008, 01:48 -
AVI,DivX,XviD to DVD with switchable subs using DVD2SVCD
By Baldrick in forum User guidesReplies: 18Last Post: 6th Jul 2007, 17:08
