  1. Help !
    I am trying to convert clips using NERO 5.5.7.2. they play OK on my computer but the problem comes when they are burnt to make a VCD. NERO does not accept some of the clips as they are and gives you the option to encode them, I think it is only when Nero has to encode the clips into the correct format prior to burning that these are the ones that come out upside down. Clips which do not need re-encoding are OK. When the VCD has been made the re-encoded clips now play upside down on my computer as well. Its not a lot of fun trying to watch with your head on your shoulder. Any sensible ideas would be apreciated.
    Many thanks,
    Martin[/quote]
  2. TMPGenc has an option to supress the upside down effect.
    Mind this settings
    http://www.homepagemodules.de/board/topic.php?&board=1213&id=46801&forum=1860
    to avoid encoding problems
  3. Will give it a try, many thanks for the info.
    Martin
