I have just created a 10 minutes long movie with imoive, and it won't let me export into quicktime. Can someone help me with that?
What software do I need in order to create a svcd or vcd with my mac G4? Toast 5?
Any help will be great
E.S.
yes, The easiest way is to install Toast 5. It includes a plug-in that allows you to export to VCD straight out of iMovie. Works nicely.
Although Toast 5 will work, I was really disappointed with the quality of the VCD as others have mentioned as well. SVCD is currently not available on the mac. There are steps necessary which, at the moment, can only be done on a PC(software not yet available). Check the forum for methods of getting SVCD using Virtual PC. It will require multiple steps, but I've heard it looks great.
From Vegas to iMovie - Does the version of iMovie matter?
By and in forum EditingReplies: 4Last Post: 11th Dec 2011, 20:05 -
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 16:56 -
Beeping on vcd/svcd
By mgdt in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2007, 10:56 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 20:25 -
How to copy-protect a VCD/SVCD v2.0
By Sine29 in forum User guidesReplies: 23Last Post: 20th Jul 2007, 10:27
