If i am creating a standard SVCD, can make the video bitrate whatever i want as long as it doesn't exceed the maximum (was the max for one cd 2520kB?)
And is there a standard bitrate for the sound too or can i change that too?
Yep, you can use anything up to 384 kbit/s for the audio
http://www.vcdhelp.com/svcd.htm#info
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 08:38 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 19:17 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 8th Nov 2008, 00:54 -
Entering Video Bitrate Makes Preset Switch To SVCD
By akulier in forum ffmpegX general discussionReplies: 7Last Post: 26th Feb 2008, 06:12 -
By akulier in forum ffmpegX general discussionReplies: 1Last Post: 21st Feb 2008, 05:31
