Hey. So I ripped my dvd of In The Mouth Of madness using DVD2SVCD and TMPGE. I'm all done with the ripping and everything but when i go to burn the files to the cd I keep getting these errors. I tried using both CDRWin and Fireburner.
Here is what Fireburner says after i load the cuesheet and hit burn:
Thread1: Executing (Cache enabled)
Recording device: _NEC NR-7800A
Firmware version: 1.0B
Recording method: Session-at-once
Recording Speed: Max
BURN Proof: Enabled
// Test burning - no data will be written to CD
Thread1: Setting Write Parameters
Thread1: Write parameters set
Thread1: Reading Disc Info
Thread1: Reading Next Track Info
Thread1: Start LBA is -150
Thread1: Sending Cue Sheet
Thread1: Error sending cue sheet
Thread1: Sense Error: ILLEGAL_REQUEST (INVALID FIELD IN PARAMETER LIST) (0x05 0x26 0x00)
Thread1: Error starting burn - Retrying...
Thread1: Error starting burn on retry
Recording aborted due to error
With CDRWin here I load my cuesheet and hit burn and this error message pops up:
Error: 'WRITE' command failed on device 1:1:0
Illegal command request (04h 00h 02h 05h 20h 00h)
Pleaaaaase someone help me out with this I am at a total loss as of what to do. Any help is greatly appreciated.
Thanks,
rw61485
Aww come on guys. Close to 30 views and not one reply??? Can someone please help me?
Sometimes I may look like an idiot, but I know you won't say anything to my face. -
in Fireburner, click "configuration",then "device options",in the box "other" untick "Test Burn" and untick "Enable BURN Proof", also lower your "Burning Speed:" to 6x or 8x for CD-R, or 2x for CD-RW.
"Peace through superior firepower" -
OOPs I posted too quickly, it looks like there's something wrong with the .cue file, I'd say remake the .bin/.cue file and try again
Firstly, try VCDEasy / CDRDAO to burn your CUE/BIN image. CDRDAO works very well.
Alternatively, if you want to use Fireburner, you can edit the CUE sheet (open up the CUE file with a text editor) and remove all the subindices (all of them other than Index 01). Fireburner doesn't fully support the CUE/BIN specifications.
Have a look at the VCDEasy site: http://www.vcdeasy.org They've got a few more ideas for burning CUE/BIN images as well.
Regards.Michael Tam
w: Morsels of Evidence -
Works Perfectly now. Thanks!
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
How to burn a .iso/bin,cue with nero
By Chupes in forum User guidesReplies: 5Last Post: 9th Sep 2009, 20:33 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 11:58 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29
