  1. I've just brought a load of copied films back from abroad, they work fine on my pc and my friends dvd/VCD player, but when i put them into my Proline dvd2000 (after entering hack successfully) they don't work - it just says no disk in player.
    any help would be great
    Jul 2001
    Maryland
    what is the format of the copies>
    Does your player support the format?
    Do you know how to tell the format
  3. no i have not got a clue how to tell the format.
  4. Buy your friend a new player & take his. You know it plays what you have.
    Or take your load of movies to the store & try them in a new player - buy the one that plays the most.
    Panasonic DMR-ES45VS, keep those discs a burnin'
