  1. I've just bought a Pioneer DVD writer and so far have not succeeded in creating any DVD titles. I tried the DVD MovieFactory demo but it won't work.
    When I try to create a DVD title or even author menus, there is a message box saying "The DVD/VCD authoring components are not properly installed, please reinstall and try again". How come? I've installed everything from the file and also have DirecT 8 installed.
    Any hints?
    Thank you for any ideas...
    Marcos.
  2. Have you installed the new patch yet?
    http://www.ulead.com/tech/dmf/dmf_ftp.htm
    Hope this helped.
    Dezine
  3. Hi Dezine!
    Thanks a lot for replying. Yep, I have installed those patches, but they were of no use. I'm still getting the same message.
    I want to buy DVD authoring package and was thinking of getting DVD Factory, but as I cannot make it work...
    Do you know any other good similar software ?
    Best Regards.
    Marcos.
