Im not completely sure what these are but I'm pretty sure they're different dvd formats??? Correct me if im wrong.
Also how do I know which my dvds are in?
These are different TV formats rather than different DVD formats per se.
If you live in North America or Japan, you will be using the NTSC system and thus your local DVDs will most likely be in NTSC.
If you live anywhere else, you will be using the PAL system and your local DVDs will most likely be in PAL.
Regards.
Michael Tam
w: Morsels of Evidence -
In addition, there are variations of the PAL system used in some countries. PAL-M, for instance, is the PAL equivalent of NTSC (i.e., 525 lines @ 60 Hz). Argentine uses PAL-N which uses 50 Hz instead. Ideally all TV sets should use a single internal chip to convert formats, at least for viewing different program sources.
With DVD and VCD one can circumvent signal formats by using the component video output.
Paulo Elias. -
I've encoded movies both NTSC and PAL, just by observation, PAL has a better quality picture, but their aren't as many frames per second as NTSC, so to me it looks a little choppy. NTSC is what I use when encoding
PAL should look no more choppy than NTSC. Indeed, anything over 24fps (film) should look smooth.
Choppiness may be an artifact from a framerate conversion (PAL <--> NTSC) rather than due to the framerate per se.
As far as I can remember, PAL everywhere in the world runs at 50 Hz except Brazil with their PAL-M. There are different colours systems used in PAL though, but this doesn't affect the VCD you are trying to make.
Regards.
Michael Tam
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 11:34
