I use a bitrate of 2520kbps on the video but theres another 224kbps for the audio, does that equal 2744kbps in total? I get very occasional freezes but it stays synced, im just curious if I should use a video bitrate of 2296kbps instead?
Which of the above is the correct SVCD spec?
Thanks, Spies.
hey spies! i own a RV-26 panasonic....i encode at 2520kbps for video....works fine with any audio setting..no jerkiness...good luck ...int
Question about SD card for Panasonic HMC150
By jeanpave in forum EditingReplies: 11Last Post: 11th Jun 2011, 22:11 -
Quick Question, Re: Panasonic SD10
By Verta in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 8th Apr 2010, 08:06 -
Panasonic Firmware question
By vetski179 in forum Newbie / General discussionsReplies: 2Last Post: 11th Jan 2009, 19:30 -
Panasonic AY-DVM83MQ vs. Panasonic AY-DVM83PQ and AY-DVM80XJ question.
By Cyrax9 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 26th Feb 2008, 12:37 -
Question on new Panasonic dvd recorders
By heman28 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 20th Feb 2008, 11:37
