My dvd player does not play cdr's, however the other day i brought a vcd that had been burnt on a princo cdr and they work no problems at all. how can you make them readable?? i really need to know please.
Results 1 to 13 of 13
Many DVD players aren't designed to read CD-R/W media and do so erratically / poorly / not at all.
You will first have to work out which brands of media work in your player. You can do this by having a look at the compatibility list on this site, or burning some audio CDs and trying them out in your player.
Then, you will have to correctly author and burn your VCDs for them to work. There are guides here on how to do this as well.
Good luck.
Regards.Michael Tam
w: Morsels of Evidence -
My dvd player is not meant to read cdr's ect...but it reads these vcds that are cdr's, and its not just my dvd player either my friend has got a different dvd player that cannot play cdrs but it can play these vcds- confusing huh?
I have tried playing burnt cds on the dvd player and it wont play them -
Do the princo media work?
In some cases, even very subtle things (e.g., burn speed, different brand CD burner) seem to have an effect on some DVD players.
Regards.Michael Tam
Confusing the say the least...
Is this even for the same batch of Princo media?
BTW, for these DVD players, CD-RW often works better so you could give these a go.
Regards.Michael Tam
its very confusing, thats why i am posting....they are the same type of princo disks and the dvd player does not play cdr/cdrw/dvdr
i cant work out how he can make these vcds work, no wounder he is making a fortune -
im guessing when you burned your own "VCDs" that you didnt go through the steps to burn a proper vcd, instead you just burned a straight data file with ur .avi
Tr3, Kt22 is right. My DVD, Hitachi 315U, states it does not play CD-Rs. But my compatibility listing has some owners state that it will play VCDs, on such media as Princo and Great Quality CD-Rs. I have been trying to make VCDs using the guides here along with Princo with no luck. So I must give him the benefit of the doubt. There is a way to burn VCDs on some noncompatible DVDs, it is just he nor I have found the right way yet. And I attempt to burn with CDRAO (VCDEasy, haha).
Hello. -
ok well thanx for ya help, i will let yas know when i come across the right way
make external DVD drive readable to media player?
By maca in forum Newbie / General discussionsReplies: 3Last Post: 4th Dec 2011, 20:57 -
Making DVD Player region free - HELP please
By djmark1 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 29th Jul 2010, 17:31 -
Need DVD Player To Play DVDrs & CDrs
By DJboutit in forum DVD & Blu-ray PlayersReplies: 3Last Post: 15th Jul 2009, 16:11 -
Only First Session readable on DVD Player-- Deep Burner
By deepakOne in forum Authoring (DVD)Replies: 1Last Post: 27th Oct 2008, 03:13 -
making a video cd which can also be played on DVD player
By d_razaq in forum Newbie / General discussionsReplies: 2Last Post: 8th Nov 2007, 18:09
