I Just downloaded PowerVCR and when I go to the options and try to select my pci cap card, the only option available to pick is my usb webcam. Yes I have rebooted the computer. Any ideas as to what I can do to fix this?
It might help us if you told us some things about your computer and your capture card (which is probably why 15 people have looked at your post and have not replied). Makes trouble shooting a little easier
It might help if you fill out the "Computer Information" section of your Profile (look up top and click on "profile", right by "register"
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
Which is better - usb stick vhs cap or hd-pvr cap + convert for vhs to dvd?
By yoda313 in forum Capturing and VCRReplies: 22Last Post: 22nd Dec 2011, 21:13 -
Cap Card Editing Issue?
By Evas1on in forum Capturing and VCRReplies: 7Last Post: 7th Jan 2010, 12:25 -
Suggestions On Buying Cap Card
By x420x Lovin in forum Capturing and VCRReplies: 4Last Post: 23rd Mar 2009, 03:14 -
need ATI TV Card replacement
By kisrum in forum Newbie / General discussionsReplies: 3Last Post: 21st Nov 2008, 21:17 -
I have questions about this ati all-in-wonder pci-e card
By yoda313 in forum ComputerReplies: 0Last Post: 6th Sep 2008, 10:23
