Hi folks. I have a couple movies that the toddlers would dig but there are a couple funky words that there little ears aren't ready for. What would be the best software/method to do some bleeping.
Mark
Assuming you know how to separate the audio and rejoin it to the video later...
The cheapest easiest solution is probably a shareware product called CoolEdit. Load the soundtrack of the movie, find the words you want removed, select that portion and replace it with silence. -
Thank you. Yes I have been extracting the audio on most movies to encode to SVCD but it didn't even occur to me to edit the audio separately. It won't throw out the audio sync by editing and saving the file though will it?
Mark -
It shouldn't affect the audio sync as long as you replace it with silence and don't just delete the offending segment of audio.
Video Editing Software: mkv, h264 & DTS Editing?
By techdls in forum EditingReplies: 8Last Post: 28th May 2011, 01:29 -
What is the best editing software for editing head
By sonic12345 in forum EditingReplies: 1Last Post: 4th Jul 2010, 21:05 -
Editing as a career / editing freelance jobs
By ayim in forum Newbie / General discussionsReplies: 8Last Post: 15th May 2010, 21:31 -
Basic editing: which Mac program for my DVD editing situation?
By Nuevonik in forum MacReplies: 4Last Post: 8th Jan 2009, 07:06 -
Censoring Cuss words
By Sonaa in forum AudioReplies: 14Last Post: 10th Sep 2007, 03:37
