I went through my files yesterday and found a huge bunch of MPEG/MPG files that I had downloaded a while back. Since I only learnt how to make VCDs yesterday, I thought I'd try them out but when I tried to burn them, I got different messages that basically had the same meaning: the file is messed up. So, I was thinking that I should convert the MPEG to MPG in VirtualDub? And then see if that works? I'm not sure if it would, and I'd really appreciate it if someone could help me. Also, when I converted from .rm to .avi using TINRA, the first video was excellent (the video and sound matched, and the quality was good) except from the second one onwards, the sound wouldn't match with the video. The video was always one step behind the audio, but the quality was good...is there something wrong with what I did? I used VDub to "scan streaming video for error" and nothing was wrong...I would really appreciate it if someone could help me. Thanks!![]()
VirtualDub doesn't encode to MPEG as far as I know.
You will need to use an MPEG encoder (e.g., TMPGEnc).
Regards.Michael Tam
w: Morsels of Evidence -
did u uncheck the make a standard complaint vcd in tmpg
u should also try to re encode them since most movies on the net are in weird resolutions -
Originally Posted by vitualis
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 19:16 -
Choppy playback of some MPEG-2 files and all IFO files
By ANOther1676 in forum Software PlayingReplies: 2Last Post: 8th May 2011, 06:04 -
Convert .mpeg-files to .vob-files?
By stuckinsnow in forum Authoring (DVD)Replies: 1Last Post: 21st Sep 2008, 04:06 -
No audio in powerdvd for mpeg 1 and mpeg 2 files
By Bully9 in forum AudioReplies: 2Last Post: 2nd Jan 2008, 07:23 -
DATA files rather than MPEG files from a DVD-Video?
By DieselsDen in forum Newbie / General discussionsReplies: 11Last Post: 14th Dec 2007, 03:24
