Hi. I copied all the vob files to my HD just like pinoy2201 said in his guide.
I opened VOB2Audio and selected the **.lst file that was created. Now my problem is that nothing happens when I cllick on soundstream. There looks to be a small dotted box in the soundstream box that was created when I clicked on the **.lst file.
Can someone please help me?
iam having the same problem it used to to work fine then it just stop finding the sound tracks and i dont have room to save these files so
some one help please -
well ive fix the prob its smartriper's fault if you dont select "all" on stream
processing then it only selects what it whants and leaves you hanging like are replys hope this helps .
Anx
Streamclip has no 16:9 option?
By jmacky in forum MacReplies: 3Last Post: 6th Mar 2011, 17:41 -
New option YouTube? 3d?!
By zovx in forum Latest Video NewsReplies: 7Last Post: 1st Feb 2010, 03:23 -
What do these option do and what to fill in these?
By tendra in forum Video ConversionReplies: 0Last Post: 30th Oct 2009, 21:17 -
The Best Option???
By Dom_Sisko in forum Video ConversionReplies: 9Last Post: 15th Mar 2008, 00:56 -
Menu Option
By k_vic in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 9th Aug 2007, 07:46
