Poll: Rank my 'Newbiness'
Be advised that this is a public poll: other users can see the choice(s) you selected.
  1. I am a newbie, and here is what I want to do:
    Record from Sony TRV25 miniDV camera, edit in Adobe Premier, export as .AVI, convert to MPEG, and burn to a CD-RW disk for a Sony DVP-S530D CD/DVD player.
    I have done the first half (imported from the camera, and edited my video), and I have my .avi file. I can play this .avi with Windows Media Player, Real Media Player, and others. Next, I am folowing the newbie directions from this site, and I know I need to get a MPEG file next, for burning to a cd-rw. OK, I have tried TMPGEnc, LSX-MPEG Encoder 3.5 Demo, and Virtual Dub. None of them like my .avi file. Here are the errors:
    I played with the .avi output settings in Premier, but nothing changed. I have tried saving the movie from Premier as a .mov, but the quality goes way down. Is .avi the right file type to go with?
    -Thanks in advance
  2. Frameserv from premiere to tmpgenc here's the guide
    http://www.videotools.net/guides/guide_premiere_tmpgenc.php
    you'll also find the frameserver there
    #videohelp on dalnet!
  3. http://www.mainconcept.com/de/downloads.shtml
    Hm... just found this. Not sure why the codec was not on my system.
  4. When selecting a codec for AVI output in a good editor, select something that is easily converted with minimum quality loss. Uncompressed is best but large. HuffYUV is also lossless and good. Some people use MJPEG. I find Indeo5 with highest quality gives reasonable results and is on most all Windows PCs.
    You might be using a DV codec which is not supported in some programs.
    Panasonic DMR-ES45VS, keep those discs a burnin'
