I am using tmpeng for encoding and when I have encoded my videos, when played back, there is a slight jump every 5 seconds, which when burned to disc is quite noticeable.
Also, I have found that my video cd's work on my DVD player and no one elses, could this be a problem with Roxio 5.5 Platinum (my current burner)
Please help me find the best authoring utils and burning software
Did you encode using the VCD template?
Regards.Michael Tam
w: Morsels of Evidence -
Yes.
I encoded using the Video CD template (PAL). I have followed the tutorial exactly that you have on your site. -
? "my site"
I don't have a site on encoding VCDs...
In any case, there "could" be a problem with Easy CD Creator... I personally don't recommend people using it. You could always try VCDEasy or Nero to create a VCD to see if that works properly.
Regards.Michael Tam
Yeah use nero
I had a hell of a lot of trouble when I used other burners.
I've found that that one works the best.
Lee -
I have now used Nero and the burning is great but I still have this skippy problem with TMPenc. Is anyone aware of a good encoder to use instead
Okay, let's try to get to the bottom of this...
Which version of TMPGEnc are you using?
Does the MPEG play fine on your PC?
Does the VCD play fine on your PC?
Does the VCD play fine on someone elses DVD player?
What is the make and model of your DVD player?
Does it have any problems play audio CDs burnt on the same media?
Regards.Michael Tam
Thanx for your help.
The reason for the jittery playback was conversion to Pal from NTSC, I was loosing framrate or vice-versa.
And I now use Nero for burning and the CD's work on all other DVD players
Help burning and playing VCD
By NLO_Cliff in forum Authoring (VCD/SVCD)Replies: 12Last Post: 16th May 2011, 09:55 -
VCD burning freeze
By Douglas879 in forum Authoring (VCD/SVCD)Replies: 4Last Post: 28th Nov 2010, 15:23 -
Burning .srt along with .avi onto a VCD
By wox in forum Authoring (VCD/SVCD)Replies: 3Last Post: 5th Jul 2008, 08:35 -
Help burning vcd
By Reds in forum Authoring (VCD/SVCD)Replies: 3Last Post: 8th Feb 2008, 07:20 -
vcd burning
By srckaimal in forum Newbie / General discussionsReplies: 26Last Post: 6th Dec 2007, 06:23
