Hi, I hve recently downloaded a film in .dat format
and i wish to burn it to cd'r so i can play it on
my home dvd player.Can this be done,if so how do i
go about it![]()
Any info will be a great help.
many thanx >>>nippa<<<
you can do this with vcdeasy. when you start the program,click >tools then>mpeg scan then on the bottom you load up your .dat file and click convert!
you now have an mpeg file ready to burn :P
Alternatively, get a copy of VCDGear, and run it through the dat->mpg conversion. Or rename the dat to mpg, and multiplex it using TMPGEnc's mpeg tools (VCD option). Then burn with Nero usinfg VCD option.
If you use burning software like Nero, WinonCD or EZCD Creator, you need to extract the MPEG file from the DAT file first. Use a software called VCDGear for this (works very well - you can find it in the Tools section).
On another note, if the file is SVCD format and not VCD, and your DVD player cannot play SVCD, you may have to re-encode to VCD. You can use softwares like TMPGEnc for that.
On a final note, if your DVD player is incapable of playing CDRs, try burning your movie onto a CDRW instead. -
The file would be .mpg not .dat if it was SVCD!Originally Posted by aguillon
"Live" picture effect - pictures end up "filmized"
By ANOther1676 in forum Software PlayingReplies: 10Last Post: 14th Oct 2011, 12:59 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 11:30 -
Review "HYFAI" MP3/MP4 "Nano" clone from ebay
By NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 06:45
