Results 1 to 9 of 9
  1. Can anybody help.
    Just downloaded a file of kazaa
    Panic room(2002).Vite.ShareReactor
    When i try to play it says unrecognised file format
    Does anybody know which codec will get the movie playing?
    Or is it another dud file of kazaa
    Im sure it was an avi file when i started it.
    Jul 2001
    Maryland
    Try renaming it to .avi and dropping the other extentions
  3. Tried that with no luck
    Still says unrecognised format
    Anyone else like aa go?
  4. the sharereactor panic room is a cue/bin file...it is in 2 parts...cd1 and cd2
    i loaded and brunt them with fire burner.work fine
  5. the sharereactor panic room is a cue/bin file...it is in 2 parts...cd1 and cd2
  6. the sharereactor panic room is a cue/bin file...it is in 2 parts...cd1 and cd2
    i loaded and brunt them with fire burner.work fine.Prolly you loaded that from someone that didnt know what to do with it and tried changing the file extension and could not find a workable combination...then put it up on kazaa for someone else to load instead of deleting it.nice guy...
  7. the sharereactor panic room is a cue/bin file...it is in 2 parts...cd1 and cd2
  8. Thanks for the reply but the version i have is in one 717,681kb file with no mention of cd1 or cd2.
    Anyone else had problem with it?
  9. the sharereactor website is http://www.sharereactor.com go there and at the top type in ...panic room...then click on the response to get the info on the sharereactor release of the movie...kazaa is good for getting incorrect files...has happened to me there...but if that is a sharereactor file it will be listed on their site.
