Hi, I ripped the Usual Suspects with smartripper. Now this movie come with 2 choices to view the movie: widescreen and full screen. The Bonus material is on the other side so its easier to handle. When I ripped it I had 2 copies of the movie one in widescreen and full screen. I deleted the Full Screen becuase I like to keep just widescreen. The movie only 3.72 GB so I want to keep the menus everything the way it is since I can fit it. But there is one problem. When you play the DVD is asks you in the beginning after you press play if you want wide or full. But since i deleted full I want to use IfoEdit to strip that screen off so when I hit play it goes straight to the movie. Now I used IfoEdit and found which VOB ID it was it was 6. The movie is 1. But when I go to strip it it only shows 1 VOB ID and thats it. Other movies I did show like 20 VOB IDS and i get to pick the ones with just the movie I cant do it with this one. Does anyone know how to take that screen off. I want to keep all the menus and everything on it.
