i read somewhere how to fix this problem, but i cant remember where or how...
tmpgenc freezes when i cut the second half of my movie that has been converted
i know the solution was something along the lines of
"press the close bracket and then move your slider to the end of the clip you want, and then press the close bracket again"
but this isnt working...so im thinking its a different method
someone help me out? any help appreciated.
I don't think there is a way of preventing problems happening occasionally when cutting mpg. You just have to try again. I find I have worse problems when cutting mpeg2. Some say when you get the movie loaded you press the play button for a few seconds. However, sometimes I can get it to lock up even doing this. 8)
I think current versions are sent out having been compiled to include sod's law code. ie, if you have lots of time and nothing else to do, it will work perfectly. If you are in a rush, it will freeze. The more time-stressed you are, the more it will freeze.
And some say it's something to do with how you hold your mouth when you do the edit.
MEGui FREEZES!!
By mark63534 in forum Newbie / General discussionsReplies: 0Last Post: 23rd May 2010, 20:43 -
AVI Freezes up
By surffx in forum Newbie / General discussionsReplies: 9Last Post: 12th Mar 2010, 05:49 -
my computer freezes
By bits27 in forum MediaReplies: 20Last Post: 9th Sep 2009, 00:35 -
XP freezes momentarily
By sdlehman in forum ComputerReplies: 12Last Post: 11th Aug 2008, 16:01 -
Vcd freezes
By notebookguru in forum Authoring (VCD/SVCD)Replies: 8Last Post: 7th Dec 2007, 15:00
