whats up,...
Does anyone the difference between the..VideoCD(NTSC)
.MCF and the VideoCD(NTSCFilm).MCF templates in
TMPEGenc..?....is it quality,time....
Thanks in advance..
LOOK AT HIM THERE..SMITHERS !!
STRUTTING ABOUT LIKE HE'S ****
OF THE WALK...WELL.I SAY HOMER SIMPSON
IS **** OF NOTHING !!
-C.MONTGOMERY BURNS-
The main difference is frames per second: NTSC = 29.97fps and NTSC film 23.976
So when you want to convert to VCD, is it better to
use the NTSC or NTSC Film template using Tmpeg?
Which one has the best quality? -
you need to use force film in DVD2AVI, then use NTSC film in TMPGEnc. 23.9 frames is better, they play smoother than 29.9 frames do, don't let anyone tell you different
<font size=-1>[ This Message was edited by: thebach on 2001-08-05 16:38:33 ]</font>
What is the difference between these two HP laptops?
By jyeh74 in forum ComputerReplies: 5Last Post: 14th Mar 2010, 16:35 -
Difference matte?
By Abiyad in forum MacReplies: 3Last Post: 22nd May 2008, 15:38 -
What's the difference between these two products?
By Waterkips in forum Capturing and VCRReplies: 1Last Post: 21st Apr 2008, 00:40 -
what is difference to + and - DVD-R and RW?
By snadge in forum DVD RippingReplies: 2Last Post: 27th Feb 2008, 12:14 -
Can YOU Tell the Difference ?
By Seeker47 in forum DVB / IPTVReplies: 14Last Post: 19th Nov 2007, 12:59
