I tried to convert a ASF
Opening C:\Howard\song1.asf
Header Obj ID OK
Data Obj ID OK
located: File property Obj
located: Audio Stream Obj
located: Video Stream Obj
-->(Video compression method is WMV1
(You might have trouble opening the avi file.
Number of Chunks: 11871
Pass 1, Analyzing...
Found 11871 Chunks
Pass 2, Converting...
Chunks Discarded:0
Chunks Converted:11871
Frame rate set to:15.04574
Frames added for A/V Sync:277, 1.5% of Total:18013
File Closed.
then when I run the avi it tries to download a codec... so I followed the link and download it... unzipped it and installed it...
still can't view the video![]()
can somebody help me?
Results 1 to 11 of 11
Download the WMV1 codec maybe? http://www.microsoft.com/windows/windowsmedia/format/codecdownload.asp
Panasonic DMR-ES45VS, keep those discs a burnin' -
right click on the avi and choose properties>Details and look at the codec info. then try to download the appropriate video codec. make sure that you have the nimo codec pack installed.
Big_Jit -
If you are converting the ASF/WMV you should select Microsoft Mpeg4 as the target for the new AVI. It can then be converted to MPEG. There is a guide on divx-digest.com on this method.
the problem is if I load it with VirtualDub 1.3c it gave me a WMV1 codec error like in ASF Tools... but I got the codec and installed it...
Look at this guide: http://www.divx-digest.com/articles/asf_wmv2avi_mpg.html
Then why did you ask for help if you do not have time?
Microsoft made it hard if not impossible to do this so people would not transcode certain files into copiable formats.
If you want an easy way to convert, select source files in copyable formats such as CD audio.
You could always pay a professional to do it for you, that's what people do if they want something without having to do it themselves.Panasonic DMR-ES45VS, keep those discs a burnin' -
Kitty is right!...
It takes time to convert video files. If you had 8GB of video to convert you should've known that 8GB of anything will take time to fillde with...
Tip,
wmv, asf, smr (and all the like) videos are for the most part not worth re-encoding to mpeg for output to vcd. A lot of people won't even suggets DivX as a good source when i've seen some better than dvd quality divX movies out there.
But hey, I've had my share of wmv movies to convert. And they all took just as long as any other video.
I'm not sayin' Don't Convert it... I'm saying try and look at which ones are worth the time and effort and which ones aren't...Big_Jit
View AVI's made with webcam ...
By Nick Marshall in forum Video ConversionReplies: 9Last Post: 15th Jun 2013, 03:11 -
Dvd to Avi to view on the TV
By andrewshouse in forum Newbie / General discussionsReplies: 11Last Post: 16th Jun 2010, 04:08 -
ASF to AVI
By Arizona42 in forum Video ConversionReplies: 1Last Post: 31st Aug 2008, 23:20 -
AVI to asf ?
By rindless in forum Portable VideoReplies: 38Last Post: 26th Jun 2007, 09:15 -
Vegas 7.0 will not let me view Avi files
By Jeff_NJ in forum Newbie / General discussionsReplies: 15Last Post: 5th Jun 2007, 13:44
