hi
new to vcd authoring and just come across your site and wondered if anyone can help. i would like to create a picture slideshow from my jgeg photo's to run on my vcd compatible dvd player to view on my tv set.
wondered if anyone else has done this before and could pass on there pearls of wisdom![]()
Refer to the "How To" guides over there in the left margin, specifically the "How To...Author" link.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
cheers for that am trying, looking at tmpg now to convert the images to mpeg. hopefully that will open it up a bit !
Use Ulead DVD PictureShow. This is a great program and very easy to use. It allows you to add music to your slide shows.
i went to walgreens and got the kodak picture cd with my develops once..
i used that as a template to create other picture cds. i just replaced the pics on that cd with my own, and it works. -
Hi!
You may try using vcdeasy 1.1.1 at http://www.vcdeasy.org it
may help you in your work.
Best regards,
Liam Kinkaid
How do I create a slideshow of photos and short movies?
By wreckage in forum Newbie / General discussionsReplies: 8Last Post: 21st Oct 2011, 03:44 -
How do I create a DVD menu for a slideshow project that I created?
By wsmitty in forum Newbie / General discussionsReplies: 2Last Post: 17th Jun 2009, 18:26 -
create slideshow
By shashgo in forum Newbie / General discussionsReplies: 27Last Post: 14th Aug 2008, 11:13 -
Want to Create Slideshow DVD to show on My HDTV
By 1deciple in forum Newbie / General discussionsReplies: 0Last Post: 7th Jul 2008, 15:54 -
App to create slideshow as video???
By vulcan4d in forum Newbie / General discussionsReplies: 5Last Post: 20th Jan 2008, 20:56
