HI need some kind of codec so i can play .cam files on WMP
sorry but i have never encountered a file extension of .cam in all my experience. cam is a descriptive term used in titling of files. it means the film was captured from a big screen using a camcorder. you might want to try renaming the file to carry an .avi, .asf or mpg extension, those are the most common and i suspect you got a file that somehow got the end of the file name cut off.
peace out,
dumwaldo
AWW MA! you know i'm not like other guys. i get nervous and my socks are to loose.
CODECs
By channelk in forum Capturing and VCRReplies: 5Last Post: 3rd Feb 2011, 22:34 -
Help D; Codec Sniper Entries/Registering Codecs/Broken Codecs
By Antischism in forum ComputerReplies: 0Last Post: 5th Nov 2008, 15:29 -
Please explain codecs to me: codecs within codecs?
By idsane in forum AudioReplies: 5Last Post: 2nd Sep 2008, 15:39 -
Where have all my codecs gone??
By Mitchum22 in forum Newbie / General discussionsReplies: 10Last Post: 9th May 2008, 12:40 -
Vista Codecs - New PC Requirements - Are Codecs Needed
By doggyofone in forum Newbie / General discussionsReplies: 6Last Post: 30th Aug 2007, 20:52
