Results 1 to 14 of 14
  1. hey guys,
    i'm trying to load the T2 .ifo into flaskmpeg, but i gives me error.
    in flask 0.594, it gives this error when opening the .ifo file:
    FLASKMPEG caused an invalid page fault in
    module FLASKMPEG.EXE at 019f:0041c25c.
    Registers:
    EAX=00000000 CS=019f EIP=0041c25c EFLGS=00210256
    EBX=00000000 SS=01a7 ESP=0148f270 EBP=00000000
    ECX=017de0f0 DS=01a7 ESI=016d61f0 FS=794f
    EDX=ffffffe0 ES=01a7 EDI=00000000 GS=0000
    Bytes at CS:EIP:
    89 5a 10 33 db 89 5a 14 8b 41 40 8d 50 ff 3b fa
    Stack dump:
    00000001 016d602a ffffffff ffffffff 00000000 017de0f0 00000000 00000002 0041bdca c5500000 ffffff84
    016d50dc 016d61f0 0041c490 016d602a 00000000
    with the lastest flaskmpeg, it gives this error (i'm using thunder mism to open up .ifo, but it
    gives me similar error):
    module THUNDER.MISM.FLASK at 019f:0472827e.
    Registers:
    EAX=ffffffe0 CS=019f EIP=0472827e EFLGS=00210256
    EBX=04759c04 SS=01a7 ESP=0112dbe8 EBP=04759a3e
    ECX=00000000 DS=01a7 ESI=00000000 FS=4367
    EDX=00000000 ES=01a7 EDI=04861e60 GS=0000
    Bytes at CS:EIP:
    89 48 10 89 50 14 8b 43 14 8b c8 81 e1 00 00 00
    Stack dump:
    04744c80 00000000 00000000 00003cbd 00003d96 00000050 00000045 047284fa 04744d80 00000050 00000000
    00000000 04861e60 00000000 00000000 963d0000
    so far, only happened with this .ifo file. also, ripped the vobs completely, no multi-angles removed or anything, so it can't be the vob files
  2. FlaskMPEG can't parse some of the more complicated IFO files.
    In these cases, you will have to use SmartRipper to rip in "Movie Mode".
    Regards.
    Michael Tam
    w: Morsels of Evidence
  3. vitualis, thnx for the reply.
    however, i need to use flaskmpeg because i want to rip the special edition of the movie (rather than just the theatrical release)... if i were to rip it in "movie mode" in smartripper, it'll strip away the seamless branching where the extra scenes are....
    so, is there any other way to get the special version of T2: ultimate ed. than flaskmpeg? how have others done it?
  4. anyone else able to rip/encode the special edition of T2, rather than just the theatrical version?
  5. come on guys, there has to be a way to rip/encode the special edition of T2..........
  6. Just use DVD Decrypter and rip all of the VOB Files to preserve all of the angles.
  7. Originally Posted by Clotz2000
    that's not gonna work...cuz after it's encoding, there will be repeating scenes in the dvd rip
    sorta like wut happens if you don't remove the multi-angles from matrix, shrek...there will be repeating scenes, however...if you do remove them all from T2, then you won't have the extra scenes...so i only know 1 program (flaskmpeg) that can parse the ifo file and allow you to choose which version of the movies you want (i.e. theatrical or special edition)...and flaskmpeg freezes when trying to read T2's ifo file..is there another program i can use instead of flask? or am i suppose to edit the ifo to where flaskmpeg won't freeze?
  8. my bad guys... it turns out (at least for t2)..that smartripper doesn't remove all the extra scenes when ripping in "movie mode"
    i checked the length of my rip against imdb.com and they match for the special edition....
    but i'm sure this may not hold for other movies w/ seamless branching...(i.e. ID4, and kate & leopold...but i'm not sure, i used flask anywayz just to make sure i got the special version and not the theatrical version)
  9. The newer version of DVD Decrypter can parse IFO files as well... Any luck doing it that way?
    It is a shame that FlaskMPEG can't parse all complex IFO files properly... I can say that it worked fine for ID4 special edition though.
    Regards.
    Michael Tam
  10. Originally Posted by vitualis
    Regards.
    hey...yea..i was able to use flask to get the special editions of ID4 and kate & leopold
    as for dvddecryptor, how would that come into play? i'm not sure how dvddecryptor being able to parse IFO files will help? dvddecryptor is used only for ripping right? unless i can frameserve into tmpgenc with dvddecryptor, i don't think it would help...i'm not very up to date on new proggies, so care to explain?
    dvddecryptor (parse IFO file)->dvd2avi->tmpgenc???
  11. No, what I mean is, DVD Decrypter will act sort of like Smartripper in "Movie Mode".
    Rather than decrypting the entire movie, it will parse the IFO and only decrypt a single title/angle. You should be able send that on to Flask then without problems.
    Regards.
    Michael Tam
  12. hrm? do you mean dvddecryptor's "multi-angle processing" option?
    i don't know where in dvddecryptor you can choose the stream/angle you want...i all know is the "multi-angle processing" option
    could it be cuz i have older version of dvddecryptor?
  13. Perhaps...
    Note, I haven't ever used that function with DVD Decrypter... it is just from what I've read from the newest version. At doom9, the latest version is version 3.something. I personally am still using v2.2 :P
    Good luck.
    Regards.
    Michael Tam
