Okay, this is frustrating for me. I have a Pinnacle PCTV Studio Pro... Just moved over from using win98se to win2k. Mainly because of NTFS not having the file size limits. Anyways I am using the drivers from http://btwincap.sourceforge.net because the Pinnacle ones seem to do nothing but drop frames in win2k for me. So now whenever I capture I could tell the audio was mono by listening to it. I just installed the PowerVCR II demo and it detects the sound as mono so I am certain it is actually mono. My sound card is an Aureal Vortex2, I also have onboard sound but it didn't work for captures, had lots of noise. Anyways I am wondering if anyone knows if this is simply a limitation or if there is a solution? I am uncertain if the Pinnacle drivers were in stereo...
I had a Pinnacle PCTV Pro myself and used the original drivers. As far as I remember, you can capture only in mono. It's no stereo card.
Anyone else?
I think I am just going to hook the audio source into the line-in and forget about putting it through the capture card.
Where Can I Buy a mono-stereo 3.5 mm mono to stereo L-adapter?
By solarblast in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 26th Nov 2009, 06:45 -
mono to stereo?
By wingfan in forum AudioReplies: 5Last Post: 22nd Nov 2008, 13:44 -
Want mono sound
By wetcamelfood in forum Newbie / General discussionsReplies: 2Last Post: 12th Jun 2008, 19:18 -
Converting a Mono Left Channel to Double Mono Left/ Right Channel on a DVD
By socool135 in forum AudioReplies: 5Last Post: 16th Sep 2007, 01:45 -
LG recorder only has mono in?
By moxiecat in forum DVD & Blu-ray RecordersReplies: 14Last Post: 11th Jul 2007, 16:32
