can someone please tell me step by step how to do this? because when i try... i dont seem to get the movie.....
1, load AVI into Vdub and scan for bad frames.
Video > Scan video stream for errors
1b If it finds bad frames,
Video >Direct Stream Copy and
Audio > Direct Stream Copy and
SAVE AS, save out another copy of AVI
2, Now that the AVI is junk free, Browse and select AVI for use in TMPGENC.
2b Select options > environmental settings
2c click the VFAPI plug-in tab
2d right click the "DirectDraw" and select higher priority, do this several times until its at the top with a value of 4
2e, browse for output filename.
3, Click load button, and open a VCD template (PAL or NTSC)
3a, click start
3c, after 3 min click stop and test your mpeg
3d, if its fine click start to convert the whole movie
4, if there is Audio sync problems go back to Vdub
4b, load AVI into Vdub
4c, select Audio > full processing
4d, select audio > conversion
4e, check the 44.1Khz
4f, SAVE WAV
5, reload TMPGEnc
5a,(Browse) use AVI for video source
5b,(Browse) use WAV for Audio source
5c, click start
5d, click stop after 3 min and test your mpeg
5e, if its fine, click start to convert the whole movie
6, well thats something else -
Heres what i want to do.. I want to RE Encode a SVCD... Its already In MPG. when using vdub and tmpgenc do they have to AVI files? cause i tried to do it when they were MPG and it didnt work.. please someone help me out
TMPGENC encoding problem
By whschlebaum in forum Video ConversionReplies: 0Last Post: 26th Apr 2011, 23:22 -
TMPGEnc Author Keeps Re-encoding
By lostinspace00 in forum Authoring (DVD)Replies: 13Last Post: 8th Apr 2011, 09:16 -
Encoding using TMPGenc 4.0 Xpress
By abdul_sma in forum Video ConversionReplies: 1Last Post: 19th Jun 2010, 08:15 -
TMPGEnc Plus Encoding
By crys94 in forum Video ConversionReplies: 9Last Post: 29th May 2008, 23:23 -
TMPGEnc Conctant or Variabile Encoding
By MI6 in forum Video ConversionReplies: 1Last Post: 2nd Sep 2007, 07:49
