  1. Ok. Im in need of assistence from the marvelous people of vcdhelp.com forum message boards. Im trying to add subtitles to a dvd backup of "hard-boiled". Ok I'm at the part were I have the subtitles ready to go. what do I do after that?? please someone must know?? I already read all the guides so dont direct me there cuz I tried and it dont work.
    It helps a lot of you tell us what method you are using(dvd2avi,flaskmpeg,dvd2mpeg squeezer) and the exact problem.
  3. Ok, Im using:
    DVD2AVi v1.74
    SmartRipper v2.3.4
    TMPEGEnc
    VirtualDub
    How do I add subtitles. I created a filter already. I just dont understand the framserveing with VirtualDub and beyond. hope this helps.
  4. Why don't you give FlaskMEPG a try?
    It will give you a quite simple way to choose a subtitle of your choise.
    Rgrds, Co.
  5. using DVD2AVI you can't get Subtitles, you must use the FlaskMPEG method instead, or if there is another method i'm not aware of, you should use that.
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
    May 2001
    Sefy that way WORKS!
    Start DVD2AVI save project, d2v and audio file is ceated, start VFAPI, create a frameserving .avi (compatibel with VDub) open the .avi (frameserving) in VirtualDub be sure to install the AVI Proxy in VDub it's an .exe file called "AuxSetup.exe" run that file and select "install handler". Then add subtitle filter and other filters when you're done Press File -> Start Frameserving -> open up TMPGEnc and encode. (Enjoy your subtitle) if any other problems or questions check out http://www.doom9.org <- You can find the exact same guide there.
    //daemon
  7. Ok, take a look at:
    http://www.flexion.org/video/DVDConv/DVD2AVI/index.html
    it'll walk you through the whole process, lots of screen shots. Also lots of programs to run. Basically:
    smartripper -> DVD2AVI -> VFAPI Codec -> VDub w/ subtitle filter -> frameserved to TMPGenc
    Another way to go is w/ DVD2SVCD from http://www.doom9.org you'll also need to d/load CCE 2.5sp (and if you want to get rid of the logo in the bottom right a crack for it). In theory DVD2SVCD is a frontend program that will run:
    vStrip -> DVD2AVI -> tooLame -> CCE -> bbMPEG -> VCDImager
    couple of notes: the only color you can make the subtitles is white (as of now, beta 12 should fix this) and it only makes SVCDs so make sure you stand alone supports them.
  8. Thanks. I figured it out. I used FlaskMPEG and realized it had english. I extracted using DVD2AVI. So I have a dubbed version of hard-boiled. Subtitle process to complicated. Thanks anyways maybe the information you provided will helpsomeone else.
