Results 1 to 13 of 13
    Nov 2000
    I am wondering if anyone knows where I could get the 99 min CDRs. And another question is are they worth it?
    I know Imation makes them
    "Computers are stupid, but they are capable of being stupid one million times per second"
  2. anyone know where you can get the 99 min cds in the UK??
  3. I've seen them at CompUSA (US). I would think you could find them somewhere online as well.
  4. Try this link:
    http://www.yesbuy.net/9099mincdrsi.html
    eBay has a few sellers as well.
  5. CompUSA has them. They run specials on them from time to time. Work well frm my exp as CD-Rs, don't know about VCD/SVCD.
  6. One of the cheapest places I have found for 90min CDR's in the uk is http://www.blankdiscshop.co.uk
  7. cheers for the link mick_r
  8. You'll also need a burner and player that are compatible, not all are....
    MO, US
    I've burned VCDs (around 90 minutes) to some of the CompUSA 99-minute CDs. I think in some places they don't have them anymore. I've found the media quality to be spotty - two CDs burned fine, the third failed, when I did a simulation on a fourth it failed, and the fifth CD burned fine. I downloaded Feurio and the CD that failed the simulation only tested good to 81 minutes.
    Actually, some of those problems might be the burner. My Sony CRX175A1 doesn't officially support 90/99min media, but those three CDs burned and play with no problems at all. It could be a matter of how far out of spec a particular disc is.
  10. Originally Posted by scottymac
    How do I know if my burner is compatible???
  11. well at least ur in the right site....clik on CD writers on the left panel.....
  12. mine isn't listed there
  13. hi !!
    << Here >> is your Writers Data from Feurio the Most new LiteOn`s support up to 99:59 Minutes
    +# HolLloZ OuthA PfalZ #+
