Hey all!
I'm trying to convert some files to AVI (an ASF and an MPG), using TMPGEnc. It worked for both, but the files are huge! 1.5 gig, when I'm seeing all of these files online that aren't more than 700 meg or so. I've tried several methods, converting directly or by separating the video and wav files. Doesn't do it to less than 1.27 gig. These are regularly sized movies, nothing huge...any suggestions???
Thanks!
The file size is defined by the bitrate you use.
for example:
1 hour movie in DVd format can be 2-3GB.
1 hour movie in SVCD format can be 1 GB
1 hour movie in VCD format can be 600 MB
1 hour movie in DiVX format can be 300-400 MB
Als of these standards use a different bitrate. So if you download a (for example) DiVx movie with low bitrates, and re-encode it to VCD format, then your filesize will increase.
If you want to encode movies and have very small files; go for DiVx. Problem is that you can see them only on a PC, and that is a shame.......The Dutchman
converting Huffuv AVI to Lagarith AVI
By abbymat in forum Video ConversionReplies: 8Last Post: 25th Apr 2008, 04:04 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 23:23 -
Converting vfr-avi to cfr-avi that produced error in picture.
By Jo The Veteran in forum Video ConversionReplies: 27Last Post: 1st Aug 2007, 23:41 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 23:22 -
Problem Converting AVI to xvid AVI (using AutoGK)
By foochuck in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jul 2007, 09:57
