Hello, I am a total newbie, so please excuse if these are really dumb questions. I've been reading over a lot of the stuff on this site and everything talks about changing the avi file to an mpeg, usually using the TMPGEnc program, and then burning that to VCD. Why do you need to do that? My boyfriend burned his avi straight to vcd the other day, he is using Nero. It seemed to play ok on my VCR (wouldn't work on his). Do you get better quality if you do that other step? How much of a difference is it? When exporting the timeline from Premiere for the avi, which is the best codec to use to get the best quality? Or would it be better to make it uncompressed, and can you then compress it when you make it the mpeg? What if you want highest quality for online viewing, plus high vcd quality? Will one way work for both, or would you need two different formats?
Thank you for any help you can provide.
Results 1 to 9 of 9
I think you are running before you can walk !. Learn the basics before moving on to more advanced topics, you cannot burn an AVI to a CD and expect it to play in a DVD player. Nero converts it to mpeg before it burns, and usually makes a right mess of it.
I know that Nero does the encoding, that's why I asked what the difference is between having it encode or using the other program.
By the way how do you get them to play on your "VCR" I tried to put one in mine, but it wont fit
TMPGENc will make a better mpeg than Nero would. -
My DVD player!
I was typing quick and it just slipped out. I told you I'm a newbie! :P
Ok, I will try out that program for making mpegs. What about the codec issue? We're having a real problem with figuring that out. If we're using Premiere and just want to make the mpeg for the vcd, would it be best to do that frameserver thing I was reading about? Or am I jumping ahead again?When we have a finished movie in Premiere, what is the BEST way to get it out so we can share it?
Nero is known to do a weak coding, most people I knw use TMPGenc with the settings descriped here
http://www.homepagemodules.de/board/topic.php?&board=1213&id=46801&forum=1860
and the guide to devode from this page. -
Do not despair, Oriecat! Help is on it's way.
The answers to your questions are just some clicks away. Take your time and read the "How Tos" to your left at this page.
Good Luck! -
Originally Posted by oriecat
As for the codec, download and install the "Nimo codec pack" V5 built 7, it has them all.
If you want to share your movies, you need to convert them to DivXthat will shrink them down half the size.
Sorry cannot help with Premiere, only used it once, not impressed with it so took it off. -
Hello, I am a total newbie..It seemed to play ok on my VCR (wouldn't work on his).
hope it helpsWell, I am the slime from your video.
Oozin' along on your livin'room floor.
Convert from MKV to AVI (mpeg-4 codec) + add subtitle to the video file
By kovacic_10 in forum SubtitleReplies: 3Last Post: 19th Feb 2011, 17:38 -
Avi to MPEG-2 quality encoding mission
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 3Last Post: 31st Aug 2009, 01:10 -
Codec choices for editing and exporting in Premier
By nhart1001 in forum Video ConversionReplies: 6Last Post: 8th Sep 2008, 18:01 -
exporting as MPEG-TS in ffmpegx
By remp in forum MacReplies: 4Last Post: 22nd Jan 2008, 20:30 -
Exporting to AVI, HuffYUV codec
By PeterK in forum Newbie / General discussionsReplies: 2Last Post: 20th May 2007, 08:21
