About to do a conversion with the CVD format with DVD2SVCD 1.9B3.
I have been using DVD2SVCD 1.09B2 before to convert DVDs
using a 4 pass VBR setting.
Can I use a 3 pass VBR setting for CVD or is it better to use the
method Baker suggested with 1 pasas VBR with a Q factor of 7?
I'm assuming the quality of both methods is comparable.
Results 61 to 90 of 187
I'm assuming the quality of both methods is comparable. -
Also, under the bitrate tab, is there a reason why the min and max avg bitrate is
set to 2400. Doesn't this make a CBR encoding instead of VBR because the min/max
avg bitrate.
Can I just leave the min avg bitrate unchecked? -
avg bitrate.
Also, under the bitrate tab, is there a reason why the min and max avg bitrate is set to 2400. Doesn't this make a CBR encoding instead of VBR because the min/max avg bitrate.
avg bitrate.
avg bitrate.
avg bitrate.
avg bitrate.
@tony yip
WHAT THE HELL ARE YOU DOING. HOW MANY POSTS HAVE YOU MADE!!!!
Yes this is too correct a bug in dvd2svcd for one pass. this is the reason htis guide will not work for multipass.Also, under the bitrate tab, is there a reason why the min and max avg bitrate is
set to 2400.
THERES THE ANSWERS TO BOTH YOUR QUESTIONS.
Baker -
IF ANYOBDY GET AN ERROR ABOUT FAILING TO SEND E-MAIL IGNORE IT YOUR POST WILL STILL BE MADE!!!!!
ALSO IS ANYBODY EXPERIENCING A STRANGE BUG IN CCE WHERE A PHANTOM 4TH CD IMAGE IS BEING MADE??? IF YOU DO IGNORE THE IMAGE. IT MEANS NOTHING AND IS ONLY THERE UNTIL A BBMPEG BUG IS FIXED. -
To get the "resize tab" you have to go to the "misc" tab and change "normal" to "advanced" where you see "DVD2SVCD level".
It's mentioned in the top of this thread. -
Just re downloaded dvd2svcd 109 b3 (6,517,272 D2S109B3a.exe)
it was a few bytes bigger than the first one I did.
Anyways didn't see that resizing tab till I loaded up the "VCD-Settings.ini" file which is installed in the home dir.
Trying my first vcd now.
l8r -
l8r -
I downloaded it 2 times but cannof find the "resize to" dropdown menu either. I am on XP.
Help. -
i have dvd2svcd 1.09 build 3 but i don't seem to have the RESIZE box on the FRAMESERVER tab.Any ideas why?
too many questions , so little time :
1) About authoring : Can I use SVCD2DVD automated tasks to create my
ready to burn CVD images ? Is needed to use I-Author or I can use other authorware ?
2) In the guide are used CBR@2400 and I need more two disks to put a movie and I do prefer use VBR@ and adjust the bitrate to fit in 2 cd. This is wrong ?
Thank You ! -
Dvd2svcd does evreything down to ceating the images. So no need to worry.1) About authoring : Can I use SVCD2DVD automated tasks to create my
My guide uses advanced vbr, however its designed to give max quailty so goes on 3cds.2) In the guide are used CBR@2400 and I need more two disks to put a movie and I do prefer use VBR@ and adjust the bitrate to fit in 2 cd. This is wrong ?
Baker -
Thanks for the step by step guide, I really appreciate it.
I tried using the settings you laid out in your guide, but all I get is a picture of the DVD2SVCD smiley face and then a solid screen with the cinemacraft encoder symbol. The sound is fine.
I am starting with an AVI file, not a DVD. I first tried a standard avi file, but it told me that the frame rate was wrong, and it kept not getting the audio extraction right so it could not make the image (I emailed you about this yesterday). I switched to a 24fps avi, and it made the image fine, but that's when I got sound and no video. What am I doing wrong?
I also could not get it to create an SVCD that was recognizable by either my computer (powerDVD) or my DVD player (RCA 521OP or 524OP, I can't remember which). I checked the specs for a standard SVCD on this site and created the mpeg 2 to match them using my capture card (Radeon 7500 all-in-wonder). The specs being 480X480, VBR less than 2.6mbs (I used 2.1), 29.97fps.
As far as getting it to see the mpeg5.1 encoder, I had to completely uninstall DVD2SVCD and re-install it. Apparently it's not a good idea to install the beta 3 version over top of the previous version.
Thanks for your help.
Ryan
DVD compliant and 60fps?
By fearmyrage in forum Authoring (DVD)Replies: 11Last Post: 28th Apr 2012, 23:51 -
Final Cut Express 4 can I create chapters for a DVD I create
By Jabroni4872 in forum MacReplies: 1Last Post: 18th May 2008, 12:36 -
making a compliant resolution mpeg2 file from a non-compliant .mkv file
By dwisniski in forum Video ConversionReplies: 1Last Post: 7th Mar 2008, 07:49 -
Anyway to make a non compliant disc compliant?
By zanos in forum Authoring (DVD)Replies: 9Last Post: 23rd Feb 2008, 11:46 -
Quality loss VHS > CVD, DVD
By rglmrj in forum Video ConversionReplies: 15Last Post: 1st Jun 2007, 13:13
