I have got a few mails about this cvd image size thing and I can greatly say ITS YOUR FAULT. yOU DIDN'T FOLLOW THE GUIDE CORRECTLY. I will have to edit the guide now anyhow so will add what you missed.
Baker
Results 31 to 60 of 187
Originally Posted by doug57
I had that problem also....skip past that part and come back at the end. After you do all the other parts it will be there. -
I had the same thing...just skip that option for the moment and do everything else. Then go back and it will be there...it was for me.Originally Posted by hitch
You have indicated that the resulting file will be DVD compliant, my question is will this create just one file? and what is the file format? I am using DVDiT to creat my DVD-Rs. I am now using some of the KDVD templates and so far they work great, but looking at the CCE, some folks indicate a faster processing time with the CCE. So I would like to try your DVD2SVCD but don't what to lose time if I have to convert the file again. Many thanks
Aloha
Bud -
@ thehutt,
I have edited the guide to fix this bug. refresh it and you will see.
@bug,
It will create about 3 files but you can burn these on s dvd-r anyway.
@baldrick,
Lately I am getting to c the message "failed sending e-mail" when I try to post. Any soloution?
Baker -
It's not because of your OS.
I followed the guide and I also noticed that the resize thingy wasn't there but I just continued the guide + setting everything in order like subtittles and stuff, the I looked back to the Frameserving tab and it was there. It appeared out of thin air. So just set all the settings you want and just before you rip and convert go to the tab and it will be there -
I followed the guide and I also noticed that the resize thingy wasn't there but I just continued the guide + setting everything in order like subtittles and stuff, then I looked back to the Frameserving tab and it was there. It appeared out of thin air. So just set all the settings you want and just before you rip and convert go to the tab and it will be there (if you are as lucky as me)
My movie is just finished and must say that the result is amazing THANX ALOT FOR THE GUIDE
ah like baldrick said use .gif with a palette of 128 colors instead of jpeg (especially at that compression ratio
) , it will look perfect and be much smaller
GuestMy first post for those who don't have the resized cd showing, go to msc tap and select advance on dvd2svcd leve..Originally Posted by hitch
Guest
go to misc tap and select advance on dvd2svcd leve and the resized cd on the frameserver should show up
Guest
On the "MISC" tab, there is a DVD2SVCD level setting, set that to "advanced". This will enable the resize option.Originally Posted by hitch
Hello Baker..
I've tried your guide, but when playing the CVD the picture ends up as a smaller 4:3 type box picture in the middle of the screen ?
The picture is Rush Hour 2 2:35:1 aspect ratio.. Why can't I get a full screen encoded version ? using CCE-CP and DVD2SVD 1.09 Build 3.
Also I found that 2 Pass VBR was better quality than the one pass.
But takes longer obviously.. Why did you choose one pass ? Speed / Quality ?
Cheers... -
I really appreciate this guide, I'd like to see more guides like this, very helpful!
I am having one problem that I cannot find a solution to on the doom9 forum. On your image of the audio settings tab, at the top there is a line that is greyed out that says "MPEG5.1 Encoder" and has a file selected in that box. That file exists in the correct folder on my computer, but that box is blank for me. When I try to encode the cvd, it gives me an error that it can't find the MPG audo file that DVD2SVCD was supposed to create. I am assuming that it is because it didn't make an MPG audio file because it doesn't know that the MPEG5.1 encoder is there. I can't select it because the box is greyed out.
Did I miss something in the setup? I followed the guide, and got all the other settings. My bitrate defaults are also a little different, for example next to "CD size 800" your image has "?-2015" and mine says "?-2013" - I don't know if this matters, but my guess is that it doesn't. The only difference for me is that I am starting with an AVI file, not a DVD (home movies captured via an ATI 7500 all-in-wonder).
Thanks,
ryan -
Did I miss something in the setup? I followed the guide, and got all the other settings. My bitrate defaults are also a little different, for example next to "CD size 800" your image has "?-2015" and mine says "?-2013" - I don't know if this matters, but my guess is that it doesn't. The only difference for me is that I am starting with an AVI file, not a DVD (home movies captured via an ATI 7500 all-in-wonder). -
@ vice.
Thnx for that boost of cofidence! The quailty is great especially block wise, its not as sharp as svcd but the quailty IS better (more detail) and there is less blocks. I think you will agree with that.
If you are really gratefull will you please post the film you encoded and the settings that you used, in my q post. The link for it is in my guide.
@RadicalEd
I have no good photo editing software so am stuck with these crap images! I would love to use gif but don't have psp or any other image editing software. Anyhow the images are still readable.
@yutepui,zaqxsw
That resize bug has been fixed now. SO there should be no more problems.
@Fred Finkle
I would reccomend changing the aspect ratio in the conversion settings to 4:3. This will provide an anamorpic picture. It will also give a better looking sharper image, this is why I will be editing this guide tonight to show this change. Thnx for pointing out my ignorence zaqxsw. I must still admit that I think 4:3 selected looks beter on a 4:3 tele as you get full screen(even though its stretched.
quote:Also I found that 2 Pass VBR was better quality than the one pass.
Cheers...
I choose one pass for speed & QUAILTY. Do test, 2pass has a more controlable and predictible file size but one pass looks much,much better and has obvisouly better speed, 1/2 the encoding time required
@Gleek
The only difference for me is that I am starting with an AVI file, not a DVD.
I never included my e-mail address in this guide because I feared getting bombarded with questions like this. U c a lot of problems ppl will have are that they are getting bugs that are dvd2svcd's fault not mine. I have been told that the avi feature of dvd2svcd does not correctly work yet so that could be your problem. I reccomend opening your captured avi in vdub and adding filters there like temporal smoother at 2 and noise reduction and resize image, then frameserving into CCE and encoding with the settings used in my guide. Then author with nero.
Now thats all those questions answered, I am away back to my tele to watch more clips of stuff to try and make this guide better.
BUG NOTE: I have recently been told that sharpen provides great results when used before resize, it should make it look like a svcd. I tried it today and each time I tried it CCE crashed.
Baker -
@ vice.
@RadicalEd
@yutepui,zaqxsw
@Fred Finkle
Cheers...
@Gleek
Baker -
About to do a conversion with the CVD format with DVD2SVCD 1.9B3.
I have been using DVD2SVCD 1.09B2 before to convert DVDs
using a 4 pass VBR setting.
Can I use a 3 pass VBR setting for CVD or is it better to use the
method Baker suggested with 1 pasas VBR with a Q factor of 7?
I'm assuming the quality of both methods is comparable.
DVD compliant and 60fps?
By fearmyrage in forum Authoring (DVD)Replies: 11Last Post: 28th Apr 2012, 23:51 -
Final Cut Express 4 can I create chapters for a DVD I create
By Jabroni4872 in forum MacReplies: 1Last Post: 18th May 2008, 12:36 -
making a compliant resolution mpeg2 file from a non-compliant .mkv file
By dwisniski in forum Video ConversionReplies: 1Last Post: 7th Mar 2008, 07:49 -
Anyway to make a non compliant disc compliant?
By zanos in forum Authoring (DVD)Replies: 9Last Post: 23rd Feb 2008, 11:46 -
Quality loss VHS > CVD, DVD
By rglmrj in forum Video ConversionReplies: 15Last Post: 1st Jun 2007, 13:13
