I have a VCD with menus all ready to burn with nero. But since I have a cracked version it always fails to burn. How can I extract the image then convert and burn with fire burner?
VCDGear has the facility to extract nrg (Nero Image) files.
You can find it in the tools section of this website. -
nero will only save .nrv files. CD mage won't open it, how can I extract a different image? Thanks in advance
A Nero image file is *.nrg - A Video CD compilation file is a *.nrv
I doubt you'll find a program that can help you open a compilation made by Nero and change it in a way you want. Spend the US$ 49.00 and buy the damn program. -
I have a program to convert and .nrg file but how do I get Nero to save my compilation in this format instead or .nrv. and buying the program is not an option because i live in Canada! That is too expensive.
If you want Nero to create an image file - meaning it takes the compilation and make a *.nrg file, you have to load your compilation (nrv file) then go to "CD-Recorder" and choose the "image recorder".
Then press "burn" a new window will appear to name your nrg file and press save. -
thanks alot. Just what I was looking for - a simple answer for a simple question
How to Extract an ISO Image without burning to dvd?
By skorpinok in forum ComputerReplies: 8Last Post: 26th Sep 2018, 02:07 -
Any programs that can extract an .IBQ image file for me?
By Bansaw in forum Newbie / General discussionsReplies: 3Last Post: 17th Jun 2011, 14:03 -
Mplayer image extract: my TGA is blue!
By RogerTango in forum Video ConversionReplies: 0Last Post: 30th Apr 2011, 13:11 -
extract music from bin image?
By pensioner in forum Newbie / General discussionsReplies: 3Last Post: 18th Apr 2011, 23:01 -
Extract Image from WMV using HEX values?
By phatz in forum Newbie / General discussionsReplies: 4Last Post: 7th Jun 2009, 14:44
